BLACK'98DSM
Moderator
- 5,491
- 3,001
- Feb 9, 2019
Alabama
Is this the stock exhaust cam?
The crane 12 cams which are getting harder to find are 246 on both intake and exhaust. The crower 2 cams are 241, and Brian crowers stage 2 are 268. Crower cams keep a low duration but have the largest lift. The stock exhaust duration is 220 or something like that. I don’t see any info on anything with a 233It's odd that they wouldn't use the same cams in all the 420a Eclipses.
you can run the stage 2 with stock cam gears. I now have stage 4, Brian crower srt4 cams! with the stage4 adjustable cams gears are a mustI got the crower stage 2s do I need adjustable cam gears to run fine on the stock ecu?
That’s what I was hoping for since I just want a fun NA car didn’t wanna do ms or max effords just to get gapped by a stock k seriesyou can run the stage 2 with stock cam gears. I now have stage 4, Brian crower srt4 cams! with the stage4 adjustable cams gears are a must
