Spyder Wire Color coding for keyless module
Gboy
Dec 3, 2021
Hamilton, Ohio
Ok bought my son a 98 eclipse spider. Bought new keyless entry. Can’t find anything tells me the color code to the plug that went into old one. Anything that would tell me what these wire go to do I can splice into new entry system would be great!
Thanks
The pages from the ManualCD are slightly corrupted here and I haven't dug to see what's in the 2G DTM on the keyless entry system.
The receiver works with the ETACS ECU so you should review it's docs too.
Here's what I could extract from the FSM pages:
Keyless receiver E-42
1 Black/Blue - Key Reminder Switch (NC with key removed, Active High = Key Out)
2 Red/Green - Door Switch Pin 1 (both Left and Right, Active Low = Door Open)
3
4
5
6 Green/Black - Left Side Door Lock Actuator
7 Yellow - DLC pin 1 (shared with Other ECUs)
8
9 Blue - Dedicated Fuse #12 Ignition ACC (Switched Power)
10 Red/Black - Dedicated Fuse #11 Fusible Link #2 (Unswitched Power)
11 Red/Green - Footwell Lights (Low Side) ETACS ECU Pin 36
12 Brown/White - Door Lock Power Relay 2 (Lock ALL)
13 Brown - Door Lock Power Relay 2 (Unlock ALL)
14 Brown/Blue - Door Lock Power Relay 1 (Unlock Left)
15 Blue/White - ETACS ECU Pin 34 (Panic?)
16
17
18
19
20 Black - Gound #8
