sputtering around 5k rpm(need help)
Status
Not open for further replies.
you are going to have to write something way more descriptive than that. Also you will get help if you post this in the problem diagnosis thread in the newbie section. Not the local meet section.
If i had to take a guess at your problem, id say a boost leak or somthing plugs/ plug wire related. You can try there and if that doesnt help, post in the problem diagnosis thread.
Yea first of all you need to post this kind of stuff in the newbie section/problem diagnosis. 2nd, you should be very descriptive about the situation.
Last reply is also what I would recommend, plugs/wires/maintenance/leaks.
PLease limit your tech posts to tech forums.
Status
