spoiler question
talon84
Apr 19, 2005
metro, Minnesota
has any one here removed the tall spoiler off of a 97-98 esi the thing blocks out my rearview mirror and looks kinda funny ita a 140 hp front wheel drive car any helpful pointers would be much appricated thanks ...... :talon:
They have been removed many times over.
You'll need to remove the trim on the bottom of the hatch inside. It's been a while since I removed mine (and just as long since I put it back), but I'm 99% certain that the trim piece snaps off (as in, there are no bolts to remove prior to prying). Start at the edges along the sides of the hatch and gently, but firmly, pry the trim away from the hatch. You will be able to tell where the clips are. They just snap out. Some are harder than others, and there are special tools which make this easier to do, but I have never used them.
Once you get the trim down, you will be able to see where the 3rd brake light is connected to the wiring harness and can disconnect that. Afterwards, it's a question of using common sense and removing the bolts which hold the wing in place. You might also remove the wiper assy, but it's not required.
Short term (and less than ideal) solution to the remaining holes, is to get some plastic plugs from a hobby shop or hardware store. Ideal solution (permanent) is to have the holes welded over and get the hatch repainted. Your call.
Dude, Keep it on, thats the one of the most sexiest parts of the car.
(oh well its up to you, plus people pay mad cash for it when you sell it)
But diggs aka the dr. (can I call you that?) set you straight!
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
