spitting and sputtering
sherloc123
982
3
Dec 18, 2002
albany, New York
i changed the tranny in my laser and all the sudden its sputters under boost and a little off boost. it sound like a leak some where and i changed out my maf sensor and i was guessing either the intercooler or the bypass valve. it didnt do it before whe changed the tranny but all the vacumn lines are connected. any clues?
sean
sherloc123 said:
yea i realize this but before i go through the hassle of building a checker
It's not a hassle, it's a necessity, if you don't own a leak tester, you're not yet a true DSMer. :p This does not apply to nt guys of course. :)
i was seeing if any one had any useful input
An useful input is to get the leak test done asap so it can at least be eliminated so you can move on to ignition, fuel and compression. With majority of these type of problems credited to boost leaks, you really can't eliminate it until you run the test.
