Somebody please help.
Update: Car is now running perfectly after 3 months. The p0100 code was from the car being run on hotwire, the mas and wiring were fine. The fuel pump was dead, switched it out for a walbro 255 and car started right up, and i did a nice 12 psi pull a little bit ago. Such a relief! I put so much time into this car and its finally done. I changed everything you can think of and thought my engine just took a crap but everything is just fine now. Fuel trims are at 0, no coolant or oil loss or leaks, car doesnt overheat as i rewired it and put a switch in the console. Timing advance was 35° during my pull. We did it guys thank you so much!
  • Wanted 6 bolt NT water pipe
    • chrisman287
