SO CONFUSED haha
Hesh724
373
Feb 7, 2009
Hopewell, Pennsylvania
I really want to use the factory bcs simply because i cant afford a good aftermarket, and i would rather use oem than some cheap setup off ebay. but anyway I am seeing Tables for "Boost" Target and Base Duty Cycle in ECMLINK v3 Full . Does this mean i cannot use my bcs as an adjustable boost contoler since i am using maf still? Just curious Thanks! there is also a Check box for enable boost control. Has anyone had any success with using link and the factor BCS? Thanks for any advice.
Maybe I don't understand 100%.
But you can't raise boost with the factory BCS, electronically. About the only way to raise boost with the factroy BCS is enlarge the bleeder hole so it bleeds more signal off the wastegate line, thus wastegate opens later.
You can make a mechanical controller yourself, it's easy. Or buy one on ebay. Just don't go with the bleeder style, go with the simple ball and spring one. It's all around a better design hands down.
