Snap ring pliers to set tension?
Sebba
Banned Member
782
5
May 11, 2006
Austin, Texas
Looking at the tensioner tool, the first thing that came to mind was using a pair of 90 deg snap ring pliers to get the job done. I can't think of a reason why this would be a bad idea.
I guess that would depend on the brand of plier you're using. The one I had in mind has interchangeable pins too.
I'm going to give this a shot.
You need that tool imo, some will tell you differently but that's because they done it before and are familiar with using something other than the required toolage. The tool is adapted to fit those 2 holes exactly and has built in 1/4 inch adapter. The factory wants you to use a 1/4 torque wrench to put the exact torque to that tensioner (In Nm). In my opinion the tool is important and if used correctly will ensure that you have the correct belt tension setup.
We've done this in the past when putting on a new timing belt. It worked fine. Our 90* pliers were a little too thick so we had to grind them down a bit but it sounds like you're onto the right idea with the interchangeable pins.
Would you mind posting a picture or link for the pliers you plan on using if you get the chance?
I don't have a picture, but I know they're available at your average auto parts store.
The brand may have been OEM...
My other thought was angled needle nose, but those I'm sure I would have to grind. The snap ring pliers look like a perfect tool for the job.
Thanks Fejery4491! How do you know when the tension is appropriate?
That's how I do it too. And I always piont the 2 holes of the tensioner towards the lowest balancer.
This way you get the right pre-tension.
The reason I do this is because whe had some customer who had leave there car in 1st gear on a hill. When they came back and started the car the belt skipped a few teeth.
I can't show you right now but what I mean is when your our looking at your frontcase, I always set my tensioner''holes'' towards the balancershaft on the right-below(the one thats on the timingbelt).
You could say the tensioner is at 5 o'clock.
Hope you follow me
What I do when I remove the hydraulic tensioner, I re-compress it so that the holes line up and I can put a pin through them. Now when I'm putting tension on the timingbelt-tensioner the pin I just put in should be moveable. This way I always know I've got the right pre-tension.
And as I said earlier, when I've done that the tensioner''holes'' are pointing towards the lower balancer.
There were times I used a snapring plier but there's a risk its snaps off and one cam skips some teeth.
Easy trick to set tension: with the "grenade pin" in the autotensioner, you roll the tensioner pulley until the pin just becomes to feel (or can be turned) loose then tighten up the pulley bolt.
Let it sit for a bit, then do your mandantory six revs on the crank sprocket, then test the pin. If the pin suddenly isn't loose or can be pulled (or turned) easily, gotta do it again.
You want that light tension on the grenade pin to be your guide for this adjustment - this gets the adjuster and pulley both where they need to be.
^ This, but I always use the Jay Racing spanner to set the tension on the eccentric pulley. 99% of the time I get it right every time. I put my new belt on my car last and had it right the 1st time. It's very simple after you've done it dozens and dozens and dozens of times... LOL
snap pliers have worked for me several times. I have been able to set tensioner perfectly so that the pin slides right out on its own. +1^^ only requires a couple ft. lbs
