Side marker/clear coner light went out
big green
644
Nov 19, 2002
Lake Orion, Michigan
My right turn signal light went out on me, but when I went to replace the bulb the new one did not work, so I tried another set, that set didnt work. I went and checked the fuses they are all are good. What could be the problem? The right one still works too, just not the left
use a multi-meter to check and see if you are getting any juice at the socket. it could be as goofy as fouled contacts in the socket to a shorted/burned/cut wire. But check for juice and then you'll know more.
Sometimes they put white grease in the socket to keep any water out. Make sure the contacts aren't completely covered with grease.
  • Wanted 6 bolt NT water pipe
    • chrisman287
