2G Serpentine Belt
DirtyDSMDan
92
Sep 27, 2011
Suisun City, California
Here is the issue, and I have searched all over the web. I was looking at my 96 Talon TSi, and I noticed something on the serpentine belt that I have never seen before. It is right above the alternator, looks very similar to an AC compressor (has tubes coming out of it.) However it is much much smaller. I will post pics up tomorrow, Its getting dark outside and I have to go to school early. I did notice that my AC compressor is not connected, but the guy who owned it previously did not disconnect it completely, just no belt attatched to it. This little compressor looking thing however is still connected to the belt, and it squeaks whenever I first start my car. Any help would be nice. Thanks
If it is, where is the power steering resevoir, or do these even have them? I am used to the big black plastic montrosities!
Its a black can that should be right behind the drivers side headlight.
If you're missing that belt it should be a little tough to turn the wheel while not moving
AC compressor is on the other side of the engine (firewall side)
ok inadvertently you answered my question. i knew where the AC compressor was, however it was that little aluminum pump that I did not know what it was. So speaking of AC compressors, will I have to pull the engine to get it out of the engine bay?
Nope, but you may have to be creative to get it out. When I replaced mine I had the intake manifold off at the time. I think you either have to remove the intake manifold or take the axle off to get it out. You may be able to remove the battery and battery tray and slide it out that way though as well. :thumb:
