SAFC to SAFCII
Coldandafraid
1,147
3
Mar 1, 2003
Edmonton,
Is the wiring harness the exact same? Can I just make the break at the halfway point and plug and play the SAFC II without actually removing the old wiring at the ECU from the first SAFC and connecting the new harness?
I'll check tomorrow to make sure, but I don't think so. I just did an AFCII to I swap so I can check pretty easily.
They are the same except you won't have knock sensor info. You would have to solder in the S-AFCII harness to get that.
