S-AFC II Grounding question
defunkt
Sep 7, 2003
Ok, quick question, I'll try to explain this as best as I can...I tried searching but didnt find anything relevant.
Anyway, I'm hooking up my safc II and I noticed that my turbo timer (also apexi) is grounded on my ECU harness. Now my question is, where should I position my 2 grounds for the safc? On which side of the turbo timer ground? Does it make a difference? Should I put one on one side of it and the other on the other? Thanks in advance.
Bryan
It doesn't matter were you ground the turbo timer ground wire. But for the super afc it has to be grounded properly, do you have a manual, the brown and blk wires are grounds that have to be grounded to the ecu harness properly, its either the brown wire before the blk or the blk before the brown. Do a search and you'll probably find more specific answers.
