Rix Racing: Jmfab T3 Manifold / Borg S369 combo & DSM parts — October 14
dacowgod
Supporting Vendor
457
287
Feb 3, 2006
Morgantown, West Virginia
Here’s this week’s mix of DSM parts at Rix Racing:
Numbers match the photos.
1. Jmfab T3 Manifold / Borg S369 combo — $2,200
Borg s369 sxe billet t3 turbo
jm fab t3 exhaust manifold
hood exit exhaust and dump
Tial wastegate
Photos, details & availability
2. 1g ECMLink 91-94 v3 with Ecu and cable — $850
As titled 1g ecmlink package with 91-94 ECU and cable
3. Evo 8,9 drag intake with boomba throttle body & tps freshly coated black. — $750
This came from an 800 awhp EVO 9 . They said it was an early AMS/Switzer manifold however there is no badging. The plenum is large. Powder Coated black and includes the boomba throttle body.
4. Fuelab prodigy fuel pump — $400
Used no fittings
5. Hx35 turbo — $275
Knockoff setup no shaft play made 400 awhp on pump gas
6. Innovate LC-2 wideband with gauge — $150
Used has some scratches bronze gauge
7. Fluidampr steel Crank Pulley DSM 1g/2g 4G63 (603701) — $325
Healthy used condition. Freshly painted the front side
8. Unorthodox racing adjustable cam gears 4G63 DSM lightweight — $300
Used see pictures has some peeling where belt rides nothing major
9. Defi pressure gauge step master VS2 blue — $150
Used good working order up to 140 psi oil/fuel
10. Defi EGT Gauge step master VS2 blue — $150
Used good working condition
11. ACT 2100 clutch 6 puck spring Hub — $325
Used like new
12. Jmfab coil relocation bracket and coils (purple) — $100
13. Mitsubishi OEM 1g BOV md160689 — $125
Used slightly
14. Mini Fuelab AFPR with gauge — $120
Used
15. Thermostat housing delete with sensor ports 4G63 (new) — $120
90-99 Mitsubishi eclipse, Evo 1-9 #35604
16. Fuelab AFPR with gauge — $120
Used faded purple-6an fitting
17. Turbosmart Vee-port universal BOV — $100
Used has some scratches see pics. Does not come with flange just tightens with Allen screws
18. ACT 2600 clutch cover — $125
Fits 1990-1999 fwd and awd turbo model dsm
19. ACT 2100 Pressure Plate — $125
Good shape! Works in any 6 bolt or 7 bolt turbo models fwd or awd
This is the pressure plate only no clutch disc
20. Spark plug cover DSM 1g or 2g made by CNC machine — $100
Freshly powder coated illusion Violet with rockstar sparkle
21. Aeromotive AFPR with line and gauge — $130
Used
22. Catch can -10an fittings — $100
Used unknown who manufactured it.
23. BLE solid timing tensioner 6 bolt 4G63 — $100
Used mt00501
24. Ferrea Valve Locks for 4G63 Evo DSM (K10035) radial grove — $100
New never used
Morgantown, WV. We ship worldwide. Photos, details & current availability: https://rixracing.com/?utm_source=d...aign=inventory_2026-10-14&utm_content=roundup
In-house dyno & automotive machine shop, CNC machining, powder/ceramic coating, engine assembly and DSM builds/repairs. We can help arrange transportation. Shipping and any listed core charges are separate.
