[RESOLVED] Oil Psi High As Hell
gsx5104
Apr 27, 2008
seabrook, New Hampshire
So I have a rebuild motor I put about 200 miles on so far and I notice my oil psi is around 90psi at 3500rpm. I have the balance shafts removed I need to know what to do. I have read about porting the oil psi relief valve. I was thinking about cutting the spring. Dose any one knows if they make a different spring or anything. If I keep revving the motor it will go over 110psi.
mine is about their... maybe more like 85psi at 4k... but i mean, if its running fine, i dont see a problem... mine wont touch 100psi all the way to redling... at idle, its EXTREMELY low, like looks about 5psi... maybe... Eh! $0.02 nothing to worry about, oil pressure is good, as long as it isnt crasy high...
