Replacing rear differential.
olddsmer
158
Mar 26, 2010
middletown, Ohio
Hello to all.
I have a B1H rear differential coming for my 93 AWD Talon. The differential only minus cups and axles. Are there some regular maint items I should replace when I do it? Axle seals or anything? For those that have done it, all suggestions are much appreciated.
Best Regards
Greg
"Olddsmer"
You can replace the axle seals just to be safe, so you know you won't have a problem, but other than that it's pretty much a bolt up and go deal. I would of course change the fluid too. I like to use the Redline Heavy Shockproof gear oil in my transfer case and rear end.;) Good luck!:thumb:
Thanks
I too like the Redline HD Shockproof in the Xcase and differential.
Regards
Greg
