<<<<<<<removing Crank Pulley>>>>>>>
g0tEclipseD
292
Oct 29, 2003
San Diego, California
Ok. Ive been at this pos for a few hours and cant get it off.
When I try to get the 4 bolts off, the pully just spins. I tried putting my feet against the pully so it wouldnt move and my friend still cant break the bolts.
What is the trick to getting that bi*** off!
i simply took a big-a$$ box-end wrench and put the open end over the center nut, and put the other end against the suspension supports.. i did this both to tighten and to loosen the 4 bolts... but now that i say this... i wonder if that woulda been possible to loosen the center nut:confused: that woulda been bad :O
anywho.. worked for me i guess :p
Just stick a 1/2 inch breaker bar in the square hole. Hold it, and break the 4 bolts free. :thumb:
