remote entry
twizdt
221
Jun 19, 2008
Madison, Ohio
After reading all the threads about keyless entry i came up 2 possibilities of remotes i need.
www.keylessride.com says i use the remote with no panic button.
The question i have is, if i purchase the remote WITH the panic button will the remote still program to my vehicle? ( 95' eclispe gsx stock security) manufactured nov 94'
The alarm does go off sometimes and it gets annoying having to walk downstairs and put my key in to shut it off.
Thanks for any responses.
so will the remote with the panic button work?
my locks are starting to get crappy too. almost broke my key today trying to unlock.
That remote will work. The '95 remotes actually have the same exact internals as the '96 remotes if you take them apart. For whatever reason, they just decided not to put a physical button for the panic function until the '96 models even though the '95 remotes still had the function built in. In fact, any remote with the code GQ43VT6T will work. If you type that into ebay you will find tons.
