95CarbonEclipse
- 1,279
- 5
- Sep 16, 2005
Yakima,
Washington
Okay, so i've been reading up on braking and suspension a lot over the past few days because I'm currently working on my GSX's brakes, but I want to maximize my time spent under the fenders. I'm on a limited budget so most everything will be OEM components.
The car already came with cross-drilled and slotted OEM replacement rotors (vented in the front, non-vented in the rear). I've already ordered a set of SS Brake lines along with replacing all the boots and seals on the front dual piston calipers. I'll definitly be adding a set of EBC greenstuff pads in the front, but...
...would there be any benefit in replacing the OEM style pads in the rear with something grippier in the rear, like EBC redstuff (Red in the back and Green in the front)?? I've read a bit about how our cars are already heavy in rear brake bias and a little bit about how having too much braking power in the rear can actually hurt stopping performance.
Would this setup be better then stock pads in the rear, worse, or not a noticable difference to spend the money? Jtoby... I'm calling on you for an answer.
