Receipts - data transfer
90gst_sean
566
10
Apr 9, 2006
Seattle, Washington
PERSONAL CUSTOMER SERVICE RATINGS (9+ outstanding /9-7 very good /7-4 did their job /4-2 very bad /2-0 wholly shit never again)
06/25/05 - Action Auto Parts - Everett, WA 4253536600
FELCS9086 - FEL PRO GASKET - $56.62
IMPOEM - HEADSET - $110.00
"OVERALL TRANSACTION SATISFACTION 7.5/10"
07/10/05 - Napa - Bellevue, WA 4257465801
148-1440 - NEW WATER - 44.19
250167 - V-BELT - 52.49
"OVERALL TRANSACTION SATISFACTION 6/10"
07/12/05 - CarQuest - Everett, WA 4252590851
LD7 40 - VAL. JOB - $205.00
LD7 35 - PRESS TEST - 28.00
LD7 25 - RESUR. HDS/BLOCK - 25.00
LB7 200 - HAZ. WASTE DISP. - 2.00
FED V-2653 - VALVE- EXHAUST - Qty 1 - 10.10
"OVERALL TRANSACTION SATISFACTION 8/10"
07/14/05 - Slowboy Racing - Indiana, PI 7243498417
49178-01470 - Mitsu Evo III 16g - $569.00
"OVERALL TRANSACTION SATISFACTION 7/10
07/22/05 - Action Auto Parts - Everett, WA 4253536600
E-2875 - KNN - (air filter) - $47.99
"OVERALL TRANSACTION SATISFACTION 7/10"
07/26/05 - M&S Recycling - R Cordova, CA 8006954700
327-58759 - EXHAUST MANIFOLD (2G) - $100.00
"OVERALL TRANSACTION SATISFACTION 5/10"
08/11/05 - Schucks Auto - Bellevue, WA 4257475888
6683726 - FAN BELT - 19.79
04/07/06 - Sloyboy Racing - Indiana, PI 7243498417
DEJ UIP-1gA1 - 1G, 2 1/2" Upper IC Pipe - $184.98
MR 187699 - DSM turbo bolt - Qty 4 - $24.00
MR 187848 - DSM turbo bolt washer - Qty 8 - $16.00
04/10/06 - TurboGarage.com
Dejon 1G Curved Intake Pipe - (extra fittings) - $115.00
Autometer dual gauge pod - $40.00
Autometer Boost Gauge - (2 1/16th 30-0-30) - $55.00
Dejon 14B/16G Lower IC Pipe - (1G DSM) - $115.00
"OVERALL TRANSACTION SATISFACTION 4.9/10"
04/14/06 - Bonehead Performance - Morrisville, PA 2152954350
Megan Racing Downpipe - (89-94 FWD) - $135.00
"OVERALL TRANSACTION SATISFACTION 8.9/10"
05/23/06 - PartsDinosaur.com - Phoenix, AZ - 6024319790
09-41204 - Head Gasket - $20.05
09-50366 - Exhaust Manifold Gasket - $9.00
09-50367 - Intake Manifold Gasket - $5.00
"OVERALL TRANSACTION SATISFACTION 9.5/10"
07/07/06 - PartsDinosaur.com - Phoenix, AZ - 6024319790
RY6768-020 - Mitsubishi 2.0 Turbo Pistons/rings - Qty 4 - $149.12
96-35MMCB - 35mm Brass Freeze Plugs - Qty 9 - $9.00
BK2 - Mits Balance Shaft Elim. Kit - $15.95
"OVERALL TRANSACTION SATISFACTION 9/10"
07/21/06 - Harbour Pointe Lincoln, Mercury, Mitsubishi - Everett, WA 4253472500
MD092785 - CAP - (balance shaft cap/cover) - $9.70
MD098626 - SHAFT, OIL PUMP DR - (balance shaft studdy) - $11.82
07/22/06 - Sloyboy Racing - Indiana, PI 7243498417
MD-0349347 - Mitsu metal head gasket - $89.99
ARP 207-4201 - 6 bolt DSM - (head studs) - $89.99
SBR-0011 - 7cm 316 SS turbo gasket - $20.00
SBR-0085 - 6 Bolt Manifold Stud Kit OEM - $35.00
08/03/06 - Auto Truck Service - Everett, WA 4252583634
BORE BLOCK .020 - $125.00
BALLANCE - (balancing rotary assemble) - $200.00
HANG PISTONS - $45.00
SHOT PEEN RODS - $42.50
POLISH CRANK - $45.00
DECK BLOCK - $65.00
MACHINE RODS - (2g to 1g "big rods") - $85.00
SURFACE FLYWHEEL - $35.00
TANK BLOCK - $45.00
Hazardous Materials - $6.88
08/07/06 - ECM Tuning - ecmtuning.com - Fredrick, MD
DSMLink base product - $595.00
ECU Repair - Qty 20 min. - $22.00
"OVERALL TRANSACTION SATISFACTION 9.9/10"
08/31/06 - DSMotor Sports - dsmotorsports.com
Aeromotive FPR -6 version 2 - (kit) - $178.25
Fuel Rail Adapter 1G outlet - $25.00
Aeroquip -6 hose - Qty 2.5' - $16.25
Mr Gasket -6 hose end 90* black - Qty 2 - $33.00
Mr Gasket -6 hose end straight black - $6.50
08/21/06 - Sloyboy Racing - Indiana, PI 7243498417
TS FG-GBCV-DS-S - TurboSmart 2 stage boost - 202.25
MR 187699 - DSM turbo bolt - Qty 1 - $6.00
02/21/07 - Sloyboy Racing - Indiana, PI 7243498417
ACT MBSD010S - ACT 2600 Street Disk - $125.00
MD749998 - Throwout Bearing - 27.26
SBR-0029 - SBR 316 SS Clutch Pushrod - $7.50
Goodridge SLB1G - 1G Clutch Line - $12.63
MD 706185 - Throwout Bearing Retainer Clip - $2.00
SNP 20009 - Stage 2 Boost Cooler Kit 2D Map - $350.52
SNP auto040 - Reverse Flow Check Valve - $28.09
SNP 40020 - 7qt reservoir - $40.59
SNP auto090 - Fluid Level Switch Upgrade - $39.95
Snow Performance Solenoid Upgrade - $32.46
"OVERALL TRANSACTION SATISFACTION 2.1/10"
"!!! I AM STILL AWAITING MY SOLENOID UPGRADE !!!"
I just received the above mentioned part(1/17/08), that makes me happier. 4/10
05/04/07 - ImportEvolution.com - N. Liberty, LA 3196656612
MD164533 - Mits 1g tensioner - $80.00
  • For sale Wideband
    • Briant91
  • Wanted 560 injectors
    • AllanL
  • For sale ACT clutch 2600
    • Briant91
  • Wanted 2g 2g rolling shell
    • DSM_Thorpe
