Recalls
2G_RFF_GST
73
3
Jan 17, 2006
Watervliet, Michigan
Some one pointed out that a problem i had with my wheel might be a recall problem. I was just wondering if there are any other recalls on 97 GSTs? Thanks in advance.
:dsm:
Here are the recalls that I found for 2gs:
NHTSA Recall ID: 00V421001
Mitsubishi ECLIPSE 1999 (99)
Mitsubishi Recall Campaign No.:
Component: SUSPENSION:FRONT:CONTROL ARM:LOWER BALL JOINT
Recall Date (Y/M):2000/12
Defect: VEHICLE DESCRIPTION: PASSENGER VEHICLES. IF THE RUBBER BOOTS ON THE LOWER LATERAL ARM BALL JOINTS OF THE FRONT SUSPENSION WERE DAMAGED DURING ASSEMBLY, DIRT AND WATER CAN INTRUDE. ALSO, MMC HAS ADDED THE POTENTIAL OF LEAKING MOISTURE, WHICH CAN CAUSE THE BALL STUD TO CORRODE.
Consequence: THIS CONDITION COULD CAUSE THE LOWER LATERAL ARM BALL JOINT TO SEPARATE, INCREASING THE RISK OF A VEHICLE CRASH. THIS CAMPAIGN SUPERCEDES MMC'S PREVIOUS SAFETY RECALL CAMPAIGN, SEE 99V-066.
Corrective Action: DEALERS WILL INSPECT THE LOWER LATERAL ARM BALL JOINT FOR WEAR. BALL JOINTS THAT EXHIBIT WEAR BEYOND THE ESTABLISHED TOLERANCE WILL BE REPLACED WITH NEWLY DESIGNED LATERAL ARM BALL JOINTS. BALL JOINTS THAT ARE WITHIN THE ESTABLISHED TOLERANCE WILL BE CLEANED AND A SPECIAL SEALANT WILL BE APPLIED TO PREVENT INTRUSION OF MOISTURE.
NHTSA Recall ID: 98V069001
Mitsubishi ECLIPSE 1998 (98)
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Recall Date (Y/M):1998/03
Defect: VEHICLE DESCRIPTION: PASSENGER VEHICLES. LOCKUP OF THE TRANSFER CASE CAN OCCUR DUE TO INSUFFICIENT LUBRICATION.
Consequence: THIS CONDITION CAN CAUSE A LOSS OF VEHICLE CONTROL, INCREASING THE RISK OF A CRASH.
Corrective Action: DEALERS WILL INSPECT THE VEHICLES FOR ADEQUACY OF THE TRANSFER CASE OIL VOLUME, TRANSFER CASE OIL LEAKAGE, AND OPERATIONAL DEGRADATION OF THE TRANSFER CASE MECHANISM. IF OIL VOLUME IS INSUFFICIENT, THE APPROPRIATE AMOUNT OF OIL WILL BE ADDED. IF THERE IS TRANSFER CASE OIL LEAKAGE, AFFECTED COMPONENTS WILL BE REPLACED. IF THE TRANSFER CASE SHOWS OPERATIONAL DEGRADATION, THE TRANSFER CASE WILL BE REPLACED.
NHTSA Recall ID: 98V045001
Component: VEHICLE SPEED CONTROL
Defect: VEHICLE DESCRIPTION: PASSENGER VEHICLES. THE DASH PANEL PAD CAN SHIFT INTERFERRING WITH THE THROTTLE CABLE CONTROL.
Consequence: THE THROTTLE CABLE CONTROL WOULD NOT RETURN TO IDLE INCREASING THE RISK OF A VEHICLE CRASH.
Corrective Action: DEALERS WILL REMOVE A PORTION OF THE DASH PANEL PAD SO IT CANNOT INTERFERE WITH THE THROTTLE CABLE CONTROL.
Mitsubishi ECLIPSE 1997 (97)
NHTSA Recall ID: 97V081001
Component: SEATS:FRONT ASSEMBLY:HEAD RESTRAINT
Recall Date (Y/M):1997/05
Defect: THE HEADREST GUIDE BRACKET WAS IMPROPERLY WELDED TO THE SEAT BACK FRAME ON THE PASSENGER SIDE SEAT BACK ASSEMBLIES ONLY.
Consequence: THE HEADREST SUPPORT BRACKET CAN BREAK, INCREASING THE RISK OF PERSONAL INJURY.
Corrective Action: DEALERS WILL REPLACE THE PASSENGER SEAT BACK ASSEMBLY WITH A NEW ASSEMBLY.
Mitsubishi ECLIPSE 1996 (96)
NHTSA Recall ID: 99V066001
Recall Date (Y/M):1999/04
Corrective Action: DEALERS WILL INSPECT THE RUBBER BOOTS, AND IF THE BOOT IS DAMAGED, THEY WILL REPLACE THE LOWER LATERAL ARM AND BALL JOINT ON THE AFFECTED VEHICLES.
NHTSA Recall ID: 96V158001
Component: FUEL SYSTEM, GASOLINE
Recall Date (Y/M):1996/08
Defect: THE FUEL TANK GASKETS FOR THE FUEL PUMP AND/OR GAUGE UNIT GASKET COULD HAVE BEEN INCORRECTLY INSTALLED ALLOWING FUEL OR FUMES TO ESCAPE.
Consequence: IF AN IGNITION SOURCE WERE PRESENT, THE FUEL LEAKAGE COULD RESULT IN A FIRE.
Corrective Action: DEALERS WILL INSPECT THE FUEL TANK AND IF THE GASKETS ARE FOUND TO BE LEAKING, REPLACE THE FUEL TANK, CAPS AND GASKETS.
NHTSA Recall ID: 94V149002
Mitsubishi ECLIPSE 1995 (95)
Component: SERVICE BRAKES, HYDRAULIC:ANTILOCK
Recall Date (Y/M):1994/08
Defect: THE HEADLAMP SUPPORT PANEL CAN DEVELOP A FATIGUE CRACK WHERE THE ANTI-LOCK BRAKE SYSTEM (ABS) HYDRAULIC UNIT IS ATTACHED, ALLOWING THE HYDRAULIC UNIT TO FALL DOWN.
Consequence: LOSS OF BRAKING CAN RESULT IF THE ABS HYDRAULIC UNIT FALLS. THIS CAN RESULT IN A VEHICLE ACCIDENT.
Corrective Action: DEALERS WILL CONNECT THE ABS HYDRAULIC UNIT ATTACHMENT POINT AT A RIGID PORTION OF THE HEADLAMP SUPPORT PANEL WITH A BRACKET AND REINFORCE THE HEADLAMP SUPPORT PANEL BY ADDING A BACK PLATE.
Sorry so long, I just copied it from another site that had alot of other unnecessary information. I also figured this would make a good reference for others.
Call your nearest Mistu dealer and see if there are any recalls that your vehicle needs done. The balljoint one listed above is one I see all the time. Those lower control arms are quite spendy so I tell customers to go to the dealer and have it done for free.:thumb:
I hate to bring up an old thread but I just got a 97 Spyder GS-T around 6 months ago and I was searching for recalls. I found this thread and see that the ball joints are a real problem, but I never had recall work done to my cars so I'm not sure what to do. Can I just call them and ask about the recalls or will I have problems being that I'm the 3rd owner the car has 93K on it and its been droped?
Nope, recalls never expire. You could be the 30th owner and they are still required to fix the problem.
Just call the dealer and they will be able to tell you if the recall has been performed on your car. Just make sure you have the VIN handy before you call. :thumb:
EDIT -> There is nothing wrong with bringing back an old thread. I feel it's nice to have as much information in the same post as possible. As opposed to having 100 threads with variations on the same question.
Im the 3rd owner of my talon, and just had ball joint recall work done. It had also been done in 2000.They do it as long as it is on the road still being driven no matter what.
silver bullit said:
The one near me says its been done once and does not need to be checked agian, i told them to check it and they said no ### its already been checked what should i do?
I would say they don't know what they are talking about since the recall applies to 2g.
If your car is broke, fix it.
Was there ever a recall on the timing belts for the GS-T's? I know these are notorious for breaking. Every car you see on autotrader that is turbo talks about having the timing belt being replaced. Or am I just stupid and scroll past it?
Thanks for bringing this back up, I forgot about this recall and I didn't know that it doesnt matter how many owners have had the car. I'm gonna go to the dealership sometime before I put my car off the road before winter to get it checked out.;)
so that was a recall then??? I couldnt remember if it was or not. Also i know this is off topic but does it matter if you have the timing belt cover off or not??? mines off right now and my buddy keeps telling me that if stuff gets in there it could make big problems too
