Rebuilding engine.
dsmman91
192
May 23, 2011
Tricites, Washington
Ok guys I'm going to rebuild my engine for turbo in this next year, my question is what is a good combo for a whole motor rebuild and I am getting all the parts to make my car turbo and I will just need to rebuild the motor and my goal for power is 350 hp out of my car cause it will be my dd.
I'd just pick up a set of nippon 1g turbo pistons, rings and acl bearings from mizzumo on ebay for 130 dollars. Some will tell you that you have to have oil squirters. They are not 100 percent necessary and many have ran cast pistons without them.
What head gasket do you plan to use?
Since your NT, your block and crank should be in good shape for a "Hone and go" build.
At the power level you want a blance job is not really needed, but I still would suggest it, even more so if you do a BSE.
The valve springs on your head maybe ok, but a set of BC1100 or Manley singles would be good to add to the build, both will work with stock retainers and should be $100 maybe less for the springs.
