Really strange/high idle
videogamemaster
129
May 28, 2008
Peyton, Colorado
Alright so I have this 1991 Eclipse GSX and it has a really weird idle that I can't figure out. It sometimes idles at 1000 but most the time it idles like its revving from 1500-2000 (can be seen in video). I tried the BISS screw and it is tightened all the way down. And truthfully I dont know crap about the SAFC-II so maybe that could fix it.
My mods are as follows:
16G Turbo
Injen Intake
FMIC
3" Turboback exhaust
550cc Injectors
255 Walbro Fuel Pump
HKS SSQV BOV
AFPR
SAFC-II
I also noticed that I am missing a belt which I believe powers the ac/heater cus neither work (its the lower belt that runs on two pulleys). I also noticed when driving that my exhaust temps on the gauge ar usually around 1000-1200 is this normal or high?
Yeah i got the same problem right now so don't worry.Look up idle surge on vfaq.com.It will be under (intake) i think.It gives you a little bit of info on it.Its a pain in the A$$.I got mine to stop that damn bouncing now it just idles at like 2 grand and then i mess with the biss and it will lower and idle perfect then i shut the car off and start it back up and then it goes back to 2 grand LOL.But vfaq will give you pretty much most of the info.Good luck
you are right, it very well could be a bad intake mani or TB gasket. I'd check your Idle Speed Control sensor like Lofty mentioned. A bad TPS (Throttle Position Sensor) would do this too. How long after venting your BOV did this start?
It's a vacuum leak. Check all the hose barbs on the intake for hoses attached to them/capped off. The other belt doesn't drive the "heater", that's powered by electricity. When you turn on the heater, do you hear a fan turn on in your dash? If not, you've either blown a fuse or the blower fan is dead and needs to be replaced. If it turns on but no heat comes out (after the car is warmed up), you either have a blockage in the heater core or your lines aren't connected.
Yeah i got pissed off cause someone spliced what i think is my isc and it didn't have a plug and ripped the wire off and and it stopped that idle from going up and down :p I just wanted the car to idle somewhat to work on it LOL.I know that wasn't probably a good move but i didn't care at that moment.I got the manual in front of me and it says the first step would be to check for vacuum leaks.So go head and start simple and work your way up the ladder.
A vacuum leak can cause idle to surge, but not from 1500-2000rpms. All a vacuum leak does is lets in unmetered air, therefore your ecu doesn't add the fuel to compensate for it, so you run lean, get misfires, and have slight idle variations. If anything a vacuum leak will lower the idle from the normal operating range due to the misfires. There's something else going on with an idle like that.
Lofty seems to be on track here, check your ISC. Then go through the idle surge list on vfaq.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
