Radio...blown fuse???
vlaar
216
Oct 9, 2002
I was hooking up my alcohol injection today. I had to hook up a power wire for the in cockpit control box. I hooked it to a slot above the fusebox under the dash. Started the car up and bam, radio goes out. Help me troubleshoot this so I can listen to my tunes again... Thanks.
the fuse box is located on the drive side fool on the left side its a black box and should have cover listin what all the fuse are
Yeah, there was a blown 10 ga fuse under the dash. However, here is the weird thing. It didn't fix the problem. The radio doesn't work, the automatic door locks don't work. Headlights, etc work and the car runs fine. Another thing. My pocketlogger doesn't work. It will turn on, but it says it's not connected (kinda odd). Help!!!!!!!
