quick wire tuck
EclipticalGS
1,449
19
Aug 25, 2008
walker, Michigan
well im cleaning up where all of the wires to the injectors, Map sensor, and whatever else is bolted to the intake manifold. I am going to tuck it underneath intake plenum itself, not underneath the whole manifold like i want to, that'll take too much modding.
My question is, is there any ill effect in cutting the map sensor wires and extending them via wire and butt splice? Because i know butt splices add resistance and im worried about the map signal getting messed up.
Also can i do the same and extend the injector wires??
Thanks, any input or an idea of something easier, tell me about it!!
Ive always read that butt connections on anything less then 8v is a bad idea due to the resistance issue. The Neg pulse that tells the injector to fire can also be effected.
So, in short I was always told to run new wire from harness to sensor. Never had any issues doing it that way, just make sure you use the same gauge wire.
There are kits online for "Re-pinning" you harness/ecu/whatever electrical connection you want to fabricate. I would suggest getting one prior to the tuck, the tools it comes with will help ensure nothing gets damaged in the process.
Good luck, wire tucks often times create problems that wouldnt be there otherwise.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
