Quick Question about radiator fans
TravisH
Mar 22, 2005
Manitowoc, Wisconsin
My ac hasn't worked for awhile and I removed the compressor when I was doing a timing belt change. I wish to remove or use the fan for it. It is the driver side fan, correct? (1g turbo)
Will there be any problems if i remove the fan? Or do people hook up the ac fan to the other one for more cooling?
If I do hook it up, I'm going to have to check the amperage it draws and up the fuse on the other circuit for the fan. Not sure if factory wiring can handle it. Anyone ever done this before?
