quick Mbc Question
JTURBOGSX
178
Jun 22, 2004
niagara falls, New York
Is there anywhere else I can use instead of teeing into bov line... I was thinking of using line that splits off turbo compressor housing. or the hose going from BCS to intake... or anywhere else. thanks
if you installed the boost controller correctly then the line that teed off of the compressor housing should be gone. Some people use the line from the intake mani (the one labeled P) but that is really only a option if you have removed the solenoids and such from the TB. According to hallmans install instructions, remove the line going from the compressor housing and the wastegate, you can follow it up to the BCS valve and remove the lines to that, leave the solenoid pluged in electrically to prevent a CEL. You will then notice 1 line from the hose you just removed goes to the intake pipe, just go ahead remove that line and cap it off with a vacuum line cap available at autozone or napa.
now run a line from the compressor housing to the MBC "source" line and another line from the MBC "signal" to the wastegate. here is a link to the hallman install directions. Please note that the MBC you are using may not have the nipples in the correct orentaion. (IE Hallmans lower fitting is for the source (or from the compressor housing), your MBC may vary.
http://www.hallmanboostcontroller.com/Pro Series Installation Instructions ld.pdf
  • Wanted 6 bolt NT water pipe
    • chrisman287
