Quick couple of Cyclone actuator questions
BurrowZ
836
5
Nov 28, 2010
Duluth, Minnesota
My Cyclone intake manifold didn't come with the vacuum actuator when I got it, instead it came with a Supra wastegate which is supposed to open at 14psi. I can get 14psi by 3k rpms easily and I think that is too early for it to open.
1. Does anybody know where I can actually get the real vacuum actuator or something like it?
2. Can I use an rpm switch (fpr solenoid in my case) with the wastegate to have it open later?
3. Can I use a boost controller to have it open later? My only issue with this is that I only want to run 25 or less psi, and I think I can still have that full boost before I want it to open which is around 4200ish.
Thanks in advance!
Thanks in advance!
use a t25 wastegate actuator and a vaccum source
cyclone intake mod dsm - YouTube
  • Wanted 6 bolt NT water pipe
    • chrisman287
