Q? on oil feed line/adapter
dsmdragon
135
Oct 11, 2006
corvallis, Oregon
Hey, I know this is going to sound like a noobie question, but I am confussed on It.
I need to know on the 420a where is my oil feed line supposed to go into the motor. Some say the sending unit, some say I can buy an adapter to fit before my oil filter and it has the fittings on it. Can someone tell me where my line is going and what fitting I need to do so. Also if there is an adapter and where i can buy it.
Thanks WTF
All i could find is people talking about the adapter you can use, but not where you can buy it. Also it sound like they where using it on the 4g63.
I guess I could just use the sending unit and put a T-fitting on the thing.
This topic(420a-turbo conversion) has been covered countless times. Do us all and yourself a favor before posting and search for the answer to your question. Chances are it's been answered and isn't too hard to find. :thumb:
As for the fitting I'm sure you can find one online to order, or you can go to your local hardware stores plumbing section and pick up the brass fittings. All the fittings can be found in post 6 of this write up.
http://www.dsmtuners.com/forums/showthread.php?t=181134
Go from the OPSU like dsmcrazy said
Oh and could you please provide full list of mods to achieve your 102mph trap, with the exception of using nitrous or a turbo, the highest traps I've seen on an all motor 420a are 95.xx from bullettdsm who also has the highest documented whp out of an all motor 420a.
  • Wanted 6 bolt NT water pipe
    • chrisman287
