Problem with Boost Control
raceprez
Aug 28, 2004
Killeen, Texas
I am having a bit of a problem. I cant seem to control my boost. I have a Profec B boost controller ( the first one). Heres the deal I just got a JDM motor put in not to long ago and i wanted to see how low i could turn my boost down. turns out it maxed out the gauge and and hit 30 psi and i hit fuel cut pretty bad. So i backed off and tried to check and see if i had a leak of any kind and i cant seem to figure it out. Just recently I ran a turbo rsx-s and now i cant get over 10-11psi which i think is what the wastegate is. i did a boost leak test and had two leaks, 1 from the BOV Flange and the other was from the coupler on the intake side of the intercooler. Both leaks were fixed and i hoped that would have fixed the problem but it hasnt. Which brings me here. Any help will be greatly appreciated.
Jon
Any ideas? This hasnt happened to anyone. The only thing i can think of is it might be the boost controller
The arm is still on sturdy theres nothin loose. What else should i check on it?
What should i check on it? the pin is still holdin and its not loose.
