420A Power window swap keeps blowing fuse.
RunaEclipse97
Aug 29, 2023
Phoenix, Arizona
Hello,
I'm currently doing a power window swap on my 1997 Eclipse RS. I have the driver side wiring installed to the relay box, but I'm facing an issue where when I connect the window switches the 30a fuse blows when I press the buttons, it didn't happen initially as it rolled the windows down at first.
Now that I try to raise it with the wiring, motor and switches being out of the door as I still have the manual roller installed still. I bought a different set of switches and the issue still stays the same on blowing instantly when being used. It happens even when the window motor isn't plugged in.
Is there anything I can do to fix this issue?
