Power resistor test - ohms
crazyquik22023
641
6
Sep 14, 2008
Akron, Ohio
hey i was wondering if anyone knows how to test the power transistor using an ohm meter. i know there is the how to on how to do it with a light bulb but id rather do it with an ohm meter so if let me know if u know how thanks
If you have access to alldata then look up the wiring diagram and connector views, should tell you specs there as well, or atleast be able to tell which pins are supposed to have continuity.
