Poly urethane inserts question
PLYMOUTH TURBO
49
Dec 23, 2008
lake forest, California
I just installed all four motor mounts with prothane inserts, is it normal for my car to vibrate a little after the installation of these inserts?
Were they the firmer mounts?
If so, then I do believe that, that would make you feel a little bit more vibration.
thats exactly what they do, I've heard a lot of people say they'll rattle your teeth out.
ive got all the mounts replaced on my tsi, with poly and its rattle's but dosent bother me too much. rattle is nothing for how long these things last.
Yes, you will feel more vibration in car. NewToBoost is right though, the extra vibration is nothing compared to performance gain. I installed the same mounts on my 97 GS-T, and it eliminated all of the wheel hop I had with stock mounts. Also, give it some driving time. The mounts should settle a little, and vibration shouldn't be as bad.
Vibration is a good thing when you install these......:shhh:That means theyre doing what theyre supposed to. You should notice a big difference.
