pocketlogger
johng96gst
101
Jul 16, 2011
Westport, Massachusetts
I have come across a palm m515, charger, usb, and pocket logger cables. I was wondering what else is needed to make this functional. Im not a tech savvy person so this stuff needs to be laid out for me.
I have the cables but saw the cables and software for sale together.
Do I need to buy software separate or is it free?
What size memory card is needed for the palm?
Any info would be helpful, thanks.
The pocket logger tuning system is very rough to today's standards, if I was you I would skip this system all together. I know it's cheap and you want to tune out the most power you can but this is not the best way to do it. Save your money and get a better system that really will give you the most power and detailed tune.
MMCD is for 1g's aide from the fact that version 1.5 is pretty dated as well as palms in genral
Any 2g that's 95/96 (the ECU) is going to be logging VERY slow regardless... as it's MUT over ODB II and you will need to use version 2.5 if using Evoscan... .
Evoscan isn't for a palm. But the best best aside from some of the Phone logging with bluetooth adapters for 2g's... .
But, I HIGHLY recomend any one with a 97+ use Evoscan As the logging rate are VERY Fast well over 100 samples a second... .
I'd spend the money on a cheap net book if you don't have a laptop over a palm any day of the week better investment and a lot less hassle in the end... .
