plymouth laser help
Status
Not open for further replies.
JOE JOE
Sep 30, 2008
Edmonton, Kentucky
I am very new at this I have had a 1993 plymouth laser for 12 years now. This car is a non turbo I have always wanted it to be a turbo. i quit driving this car 7 years ago put it up with a new paint job. I then got caught up in life going thew the turbo diesel trucks and stuff. I have decieded to pull the laser 2.0 out with 106000 miles out and drive it again my question is can I put a turbo kit on this or would I be better off with the motor swap it that's the case I need to know your opinion on what motor to put in it year model ect. :laser:
You can turbo the n/t (assuming its 4g63), well I mean you can turbo most motors given fabrication work etc.. Bear in mind the pistons have a much higher comp ratio compared to the turbo4g's 7.8:1 (iirc) so you can't go crazy on the boost.
Can you do it fairly cheap? Yes.
Is it specifically easy? From what I've read (and I know a guy irl that did it) it's not too difficult to do if you're mechanically inclined.
Should you get another motor? Well that's a preference question. If you don't want to full with anything and know where you can get a good priced 4g63t fwd than maybe that'd be better. If you've got the time and the tools it complicates the answer.
Goodluck :talon:
from what have read it does have the 4G63 motor. I just was wondering will the turbo kit for a egle, eclipse work on my 1993 laser and one more question is my car 1 generation?:confused::confused::confused::confused:
Status
  • Wanted 6 bolt NT water pipe
    • chrisman287
