Planning on running 30psi, which headgasket do i use?
highintenzity4 said:
If I have arp headstuds is the oem headgasket going to do fine? Thanks guys.
Why would you invest in ARP head studs and then use an OEM headgasket in hopes of running 30psi? Get something better. 4layer steel OEM would work nicely.
Well to run it safe some ARP head Studs and a Cometic High Pressure Head Gasket it has always work well for all my cars. :dsm:
Is it neccessary to machine the head and block deck before installing a cometic HP headgasket?
  • Wanted 6 bolt NT water pipe
    • chrisman287
