Pic Request
greenmeanie99
237
Feb 3, 2005
Lancaster, Pennsylvania
Crunch time for me is now. My car is just about done. Everything is installed and ready to go except the down pipe. On Friday I have an appointment for an exhaust shop to fab the pipe. If possible could i have some pic's of a few angles of what others have done. Also I know its going to be a tight squeez because the t3 flange is in the center of the manifold so i already bought the heat wrap for the DP and Rad hose. Thanks in advance. :sneaky:
hey man check the pictures in my profile, if you got your manifold from the jason guy off ebay then this is what the muffler shop did for mine, it going to look crappy, but hey it works, the DP is really close to the radiator hose and a/c lines so now I have my rad, hose and my A/C lines wrapped in it, plus the DP. Good luck and Happy Boosting my friend! :thumb:
P.S. Don't let the Boost bug bite, he is very addictive!!!!!!!!!
that is exactly the same manifold and same waste gate I'm using so that helps me out sooo much. Thank you. :thumb:
yeah man any time, keep us updated on your project, I believed my muffler shop used 2.25 inch pipe for my exhaust, it was the biggest they could use for the curve of the radius. They had to break off the bottom stud on the turbo so they could bend it staight down, and hooked it up to the down pipe. Mine didn't have any exhaust leak with the stud being broken off, they just tighten the top two real tight and I also used a 3 bolt flange gasket which prevented exhaust leak as well. Hope this will help you some more.
Andy
  • For sale Mishimoto Intercooler
    Universal Mishimoto Intercooler $100.00 Brand new
    • jmt2028
  • For sale 2g Mahle Power Pak Pistons
    2g Mahle Power Pak Pistons, factory bore $350.00 Brand new with wrist pins and extra set of...
    • jmt2028
  • For sale 2g Water Neck/Thermostat Housing
    2g OEM waterneck and thermostat housing $60.00 In good condition, came off 1995 Eagle Talon Tsi
    • jmt2028
  • For sale EVO 9 Blow Off Valve
    EVO 9 blow off valve $60.00 In good condition, came off 1995 Eagle Talon Tsi. Comes with factory...
    • jmt2028
  • For sale 2g OEM Camshaft Gears
    2g OEM Camshaft Gears $80.00 In good condition, came off 1995 Eagle Talon Tsi Comes with OEM...
    • jmt2028
