PCV Valve Threads? 1/8" BSPT 28 tpi
The PCV valve hole on the VC is a 1/8" BSPT with 28 threads per inch. The 1/8" NPT have 27 threads per inch. Just be sure to Re-tap it before you try threading a 1/8" NPT fitting in there.
If you must use -6 line ignore this. But I just used one of the vacuum fittings off the stock intake manifold and it screws right in, since the threads are identical to the PCV valve's threads. But I also use normal fuel hoses with clamps on my oil catch can setup.
