Parts For sale
Status
Not open for further replies.
vr4_3000
57
Feb 11, 2008
Marysville, Washington
well since I cant post my ad in the classifieds and the modorators wont communicate with me...... I have decided to post here and hopefully they will move it. Sorry mods
Ok so there are there are 3 options here.
Buy my 1998 which already is converted from FWD to AWD. All it needs is 2 new cv axels in the front and to be put back together which i can do. If you buy the car you get everything on this list. And any other parts I have including any nuts/bolts/mounts i have. $7500
Buy everything that is needed for a FWD to AWD Swap. Includes everything from the transmission to the rear end. $3500
Or buy whatever parts you need
Yes i will take obo. Please no lowballing
here is the list of parts
AEM Adjustable Fuel Pressure Regulator $50
Skunk2 Cam Gears Pro Series $200
Coil On Plug Setup $150
ARP Head Stud kit 7 Bolt never been Installed$125
Stainless steel oil feed line $20
O2 Bung $5
40MM wastegate flange and Gasket $15
Oil Filter sandwich adapter with 4 ports $50
Complete 2g Tail lights off of a 98 Spyder $40
GT37R Garrett Turbo with Precision Turbo A/R.63 exducer housing (ceramic Coated) matched with a A/R70 compressor. Oil and Water Cooled $1200
95 EPROM ECU Socketed for ECMLink (Also know as DSMLink) $250.
VIS Carbon Fiber Hood $150
AWD Starter $50
AWD hydrolic Clutch Booster $20
AWD Big Brake upgrade Front Calipers (Red High Temp. Ceramic paint) $100
AWD Rear Calipers (Red High Temp. Ceramic paint) $75
AWD Rear Cross drilled/Slotted Rotors $125
FWD Stock Calipers $40
2G Transfer Case $75
2G AWD Transmission With Jacks Transmission rebuild with Evo III 1st and 5th and transfer case rebuild $1500
AWD Gas Tank $100
AWD Drive Shaft $75
18 Inch ADR 5 spoke spilt rims. 3 have toyo proxy tires 215/40/18 one is just a rim. are in good condition. $400
2g Power steering rack $75
2G rear torsion bars $50
2G Mishimoto aluminum race Radiator $175
2G Head with Blox Cams (272/272) without Valve cover or cam Gears $200
4g64 motor with 2G DOHC head, No cams, 7 bolt with turbo oil pan. $1000 or with a set of Brian Crower 4G63 Stage 4 cams for $1300
Brian Crower 4G63 Stage 4 cams $350
4G64 Complete with intake manifold and throttle body $75
2g intake ported for a 60mm throttle body $75
1g 60mm throttle body $50
2G Brand new Still in plastic front bumper $200
2G Gun metal grey rear bumper $100
2g Triple pod cluster with Oil pressure gauge and sensor/Boost pressure gauge/ And Pyrometer gauge and sensor $250
2G Dual pod insturment cover $40
Glow shift Oil Temp Gauge and sensor $50
2G no name short shifter $10
2g B&M short throw shift kit. with 35% 0r 55% throw reduction $100
8 450cc blue top DSM injectors. All within 3% or each other $75 for a set of 4
2g Windsheild washer Resivor $10
2G Infinty Amp $15
2G Ignition Coils $25
2G LSD 4 bolt rear end with sub frame and all things attached with brand new wish bone linkage still in bag $1000
1998 Eclipse spyder GS with working top and all interior minus the seats. $1000
I have more pics on request.
contact me at [email protected]
or text/call
425-346-0104
Status
