Parting out/whole 91' Talon TSi AWD
TaLN91tsI
74
Aug 29, 2012
Sacramento, California
Been on this forum years ago, great info and folks. But my time has come to move on from my DSM tuning/playing. So, parting out or whole car with spares:
1991 Talon TSi AWD
Engine: HKS VPC, AEM underdrive pulleys, AEM adj cam gears, boost sensitive aux fuel pressure regulator with gauge(underhood), Fidanza alumin flywheel, fresh head (street ported with 5 angle valve seats)...
Trans: TRE performance rebuilt 5 spd trans with steel shift forks and upgrades syncros
Suspension: Koni adj shocks/struts
Brakes: 3000 GT front calipers and rotors
Extras: 2 transfer cases (1 alumin, 1 cast iron), 5spd trans
This list is incomplete and I will be updating daily.
1991 Talon TSi AWD
Hi is there any part on your car that will fit or directly bolt on my 97 gsx?
Yes, there are lots of 1g to 2g parts... Check out other threads or find a parts interchange guide online
Parts update:
Engine: HKS VPC, AEM adj cam gears, boost sensitive aux fuel pressure regulator with gauge(underhood), Fidanza alumin flywheel, fresh head (street ported with 5 angle valve seats), APEXI AVC-R, 4 ea NGK non-resister racing plugs (R5671A-8),4 ea Denso plugs (W20EXR-U#4), 2 ea stock MAF sensors, stock air filter and housing, 1 stock ECU (core)
Trans: TRE performance rebuilt 5 spd trans with steel shift forks and upgrades syncros, ACT racing clutch,
Suspension: 4 ea Koni adj shocks/struts, 4 ea Voltec 18x7.5 alumin wheels
Brakes: 3000 GT front calipers and cross- drilled rotors, rear cross-drilled rotors, EBC brake pads (installed f & r)
Extras: 2 transfer cases (1 alumin, 1 cast iron), 5spd trans AWD, 2 stock stereos (Double DIN), 2 ea Schroth 4 pt racing harness, 2 ea Cobra race seats, Momo F1 flat bottom 13” steering wheel w/Longacre quick release
Stock AWD trans $600 TRE AWD perfm rebuild $1200
I wiil work on a price list and post with car pics after work today
List Update
Since I’d like to get rid of the entire car, just ask about pricing. If I do not get any interest for car as a whole, I will definitely part it out completely.
Engine: HKS VPC, AEM underdrive pulleys, AEM adj cam gears,Paxton boost compensating adjustable fuel pressure regulator with underhood gauge, Fidanza alumin flywheel, fresh head (street ported with 5 angle valve seats), APEXI AVC-R, 4 ea NGK non-resister racing plugs (R5671A-8),4 ea Denso plugs (W20EXR-U#4), 2 ea stock MAF sensors, stock air filter and housing, 1 stock ECU (core), 3000 GT VR4 in-tank fuel pump
Suspension: 4 ea Koni adj shocks/struts, 4 ea Voltec 18x7.5 alumin wheels, Eiback 2” lowering springs
Extras: 2 transfer cases (1 alumin, 1 cast iron), 5spd trans AWD, 2 stock stereos (Double DIN), 2 ea Schroth 4 pt racing harness, 2 ea Cobra race seats, Momo F1 flat bottom 13” steering wheel w/Longacre quick release,
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
  • Wanted 2g Finish My Project!
    I am in need of some big ticket items in order to finish my project. In my engine bay there is...
    • dhssoccer24
