Resolved P0100, P0105, P0110 codes
ryancampbell98
118
40
Mar 24, 2023
Wildomar, California
I received all these codes in the last week. In the last two weeks I’ve installed an FP Manifold, 3” Catless downpipe, 3” exhaust. I also cleaned the throttle body, MAF sensor, installed a new PCV and added a fuel system/injector cleaner. What may be the cause of these codes popping up? The car drives completely fine.
You cleaned the maf? Dsm use a Karman vortex type mas that does not require cleaning. Yiu likely ran the car with the maf unplugged. Check connection, reset and see if it comes back.
They were dummy codes. Caused by me replacing the manifold and installing a dp unplugging O2 sensors etc. Cleared the code and they never came back.
They weren't dummy. All 3 of those are in the maf sensor. The most common cause is accidently leaving it unplugged after maintenance.
Yea I left the maf unplugged after cleaning it and drove on accident . Maybe that’s what it was they are all gone now
