Only 2 coolant sensors? Where's the 3rd?
ChiGGz
280
Aug 29, 2005
Toronto,
I bought the car 1gina2g swapped.
So I wanted to install a new thermostat since I've been told that 170 is below operating temps.
Looking around at the wires, I noticed my car only has two.. One goes to my water temp gauge (aftermarket), and the other was the fan switch and what also feeds the ECU at the same time because my car wouldn't start on a cold day or the fans won't turn on without it plugged in.
Is this an OK setup?
Here's a picture, for clarification, there is a coolent temp switch where the T style plug should be. The left hole where there should be a sensor is blocked off with a screw
EDIT: So reading around apparently one is for the AC which this car doesn't have :) Which plug should be for AC then?
One more Q, what gen thermo stat should I be buying?
There are only 2 on a 2g. One for the ecu and one for the gauge. So when you have a 1g head, you have alot of extra ports. Just leave watever is in there to block them off and just use the 2 you use. My car is the same way.
  • For sale Wideband
    • Briant91
  • Wanted 560 injectors
    • AllanL
  • For sale ACT clutch 2600
    • Briant91
  • Wanted 2g 2g rolling shell
    • DSM_Thorpe
