AWD-Tony
- 6,787
- 3,748
- Sep 11, 2017
Cincinnati,
Ohio
Did the first oil change after the 500 mile break in going from 10/30 to 20/50 and now my oil pressure is a bit high, 80 cold start and 30 warmed up. Plan to shim the oil pressure regulator on the ofh. Does anyone have a spare laying around to give me the diameter of the bolt so I have a crush washer handy? Not sure if it’ll keep leaking oil while I have the regulator bolt out.
Edit: I let it warm up a bit longer and got it to 23psi. Still want to shim it
Thanks, Tony
Thanks, Tony
