Oil Drain Plug Problem
pitbullowner_2
205
4
Dec 22, 2005
ashton, Illinois
i went under my car to do a oil change and when i started to turn the drain plug it was extremely tight and every little turn i was doing the plug was not backing out at all i have probably turned it about 1.5 turn by know and it has not backed out at all yet. i dont want to break it off but it feels like it got cross threaded or something. any ideas would be great the sooner the better b/c we all know that it isnt good to go without changing the oil especially in a dsm.
1. You shouldn't bump your threads, it'll get locked.
2. You won't break the oil drain plug, however, you/whoever probably cross-threaded the plug when it was installed last and will now strip the threads on the pan/plug removing it. You can use some PB Blaster on it and give it a try if it's just stuck.
3. Then if it's stripped you will have to drop the pan, go to AutoZone and pick up a new slightly larger plug and re-tap the pan.
damn that sux just to do a "simple" oil change i'm gonna take it to my uncle he's a mechanic and see if he can back it out without screwing things up probably on saturday. but if anyone thinks of something before then let me know.. o by the way i did spray some stuff on it with no success...thanx anyways
