o2 housing and injector problem
95blackclipse
Jan 12, 2006
Homestead, Florida
Ok first off i was installing my evo3 16g with the ssautochrome o2 housing(flame on)fit fine on the turbo. when i go to connect the 02 housing to the downpipe (stock downpipe for now) i got the first screw in and when i went to do the one towards the passenger side, thier is not enough space to put the bolt in. i know some of you guys have installed this before any feed back would be great.
Problem #2 I have a set of rx7 injectors purple tops and when i went to put them in the tip that goes into the head is a little too big, it barely goes in? any tips?
The ssoutochrome O2 housing was probably machined wrong you will have to grind the hole in the dp so that they fit then attach them togather. I have no clue about the RX7 injectors I have densos and that is all I have ever messed with on a DSM and I would sell then and go to denso or some other brand. BUt good luck to ya.
