No wires for cd player
95tsiwhite
Feb 4, 2006
warsaw, Indiana
I recently bought a 92 eagle talon and the owner had stripped the car completely except for the dash and when i looked for the connections to hook in my cd player i notice there was no wires. does anyone know how i would go about hooking up new ones?........ would it be easy or could i run every wire seperately?
If there are no wires there at all then he must of cut and hacked the wiring. If you are 100% positive that the wires are no there then You could put another wire harness in the car (which will be a pain), or you could run the wires yourself which isn't fun but its better than replacing the harness.
Here is a link to the wiring diagram: http://vfaq.com/mods/wiring-1genplug.html
If you want to run your own wiring than each wire from the headunit will go as followed below:
BLACK-ground, connect it to the chasis
RED-ignition/12v, connect it to an ignition source
yellow-memory/6v, connect directly to the battery
white/white-black-front speaker
grey/grey-black-front speaker
purple/purple-black-rear speaker
green/green-black-rear speaker
each speaker gets 2 wires one +(positive) and one -(negative), the wire with the black line goes the positve end of the speaker.
thats all the wires you will need to hook-up.
