Nipple!!!
spectr019
254
Oct 28, 2004
East Lansing, Michigan
so i've gotten some of my hoses confused. What hose connects to the nipple (on a T25 or T28) inbetween the compressor inlet and the lower intercooler pipe arm? I'm pretty sure it is one of two choices: It is just a straight hose from the nipple to another nipple on the air intake pipe. OR I use a T-fitting to tap it into the hose from the actuator to the boost controller.
I'm thinking it just goes to the intake pipe, but that's just my guess. Thanks for your help
Ben :talon:
muchas gracias you two. I'm right in the middle of putting in my FP Big 28 and I was looking at hoses and was thinking that something just didn't add up, and I knew there would be some smart DSMers on here who could help me out. Thanks again.
i just plugged it and ran the boost controller like normal T'd off the BOV.
Do this, or run a line from it to your MBC as your boost source.
it's been my boost source since I put it in, but I always hear that the source should be the pressure of the manifold. But if I don't like it from where I relocate it, then I'll just put it back, no big deal.
The place where you tap your MBC on your intake tract (as long as it's after the turbo) isn't super important.
Where you tap your boost gauge is though. The boost gauge should be tapped from your manifold b/c you want to measure what psi your engine is seeing.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
