Next Mod Stage - Suggestions
Red Recluse
58
Sep 7, 2004
Ormond Beach, Florida
9SecondRacing.com
Part Price
Injen Intake (w/ aftermarket bov) $199
Apex Super AFC 2 319
Apex N1 Catback Exhaust 469
Apex N1 Downpipe 209
MSD 4 Tower Blaster Replacement Coil 74
Greddy 2 Row Type 18R FMIC 769
Greddy PRofec e-01 510
Total $2,549
AGPTurbo.com
Garrett T3/T04 Upgrade Kit 1650
Turbo XS DSBC 224
Total 1874
Pocketlogger.com
Pocket Logger OBDII 125
HotSync Cable 19.95
Total 144.95
DSMPerformanceParts.com
RC 550cc Injectors 298.95
Walbro 255lph Fuel Pump 109.95
Total 408.9
Over all Total $4,977
Items Needed
Palm Pilot
Magnecor 8.5mm Wires
NGK Iridium Plugs
Paint and Rollcage
Wheels / BFG KDW2s
Sparco Tournio's
System?
Sway Bars
Strut Bars
Steering Bushings
Steering Wheel
Shifter Bushings
Short Throw
Interior Carpet
This is a rough draft of what I am thinking of doing, I might need to get a new motor due to crank walk, but I'll find out about that tomorrow. Does anyone recommend any different parts/places to buy etc? (Some of this I'ma try to ebay but...)
Chage to a greddy 24row at least. If not get a SBR/AGP/Victory/DVDT Intercooler
What size turbo-50-trim,57-trim, 60-1?
No need for the replacemant coil.
No iridium plugs.
Actually I'm going to stop right there.
First you should get your basic mods on,
Gauges,Intake,turboback exhaust,boost controller,FMIC (so you don't have to upgrade IC pipes twice) and a BOV. As far as the FMIC ditch the 18r and get a 24r if you really want a greddy, otherwise an AGP/Slowboy/victory/DVDt/AMS would be better choices.
Once you get those mods on then come back and start on more.
Clutch
pump-255
Injectors-650's
AFPR
DSMLINK
Bigger turbo
You need to start of slow.
No iridium plugs.
Clutch
pump-255
Injectors-650's
AFPR
DSMLINK
Bigger turbo
Should have noted a few things. As of right now I have TurboXS RFL, TurboXS HP BC, Full 3" exhaust with Magnaflow muffler, hard upper piping. I have EGT, Boost, A/F (even though it's pointless but I like to monitor it due to last dyno run A/F ratio was like a 16.5) Clutch is ACT 2100 with XACT Flywheel. 24r is good too, was just trying to get all the parts I want and thought sacrificing 6r wouldn't be too bad.
As far as the plugs I was to damn lazy to go look up what NGK's we are supposed to use and iridium was the first thing that came to mind...
The turbo options are as follows with the kit...
Includes: AGP/SFP T3 manifold, TiAL 38 or Turbonetics Evolution Wastegate, Stainless Steel dump tube, 57 or 60 trim T3/T04E, 2.5" Stainless Steel O2 housing, oil feed line, oil drain tube, gaskets, nuts, and bolts. Available turbine housings - .48, .63, .82, 1.06 A/R ratios. Available turbine wheels - 76 trim T31, 76 trim T350.
First you need to decide your goals once you decide those that will determine the tubro size you want, which will then determine your injector size,pump size, and tuning method.
Any suggestions as far as turbo size? The motor is stock, nothing forged etc... Basically I'm looking for the car to be putting down around the 300's... Nothing insane but maybe in the mid 12's without spray...
Basically a car that will pull on the highway, but still a daily driver....You know every DSM'r has/wants a 12 second grocery getter.
So here's the updated list. Can the EvoII be externally wastegated? I want to use an O2 dump. And also thanks to everyone who helped.
Flow Mods:
Injen Intake
Turbo:
Slowboy Racing Intercooler w/ Kit
EvoIII Big 16g
Exhaust Manifold with O2 dump
Wastegate (Tial 40mm?)
Engine Management:
DSMLink
Autometer Boost Gauge
Autometer EGT Gauge w/ probe
Motor:
1st gen (or equivalent) throttle body
Intake Manifold ??
HKS cams (264 degree intake, 272 degree exhaust)
Fuel:
660cc Injectors
Denso/Walbro 255lph Fuel Pump
Ignition:
NGK BP7ES spark plugs
Magnecor 8.5mm wires
Flow Mods:
Injen Intake
Turbo:
EvoIII Big 16g
O2 Housing Dump
- Anyone actually have the Exaust cutoff? Worth it yes/no?
Engine Management:
DSMLink
Motor:
Fuel:
660cc Injectors
Ignition:
When I had one custom bent, the pipes were crush bent, and theres a gap in the piping where the O2 sensor is....it goes from 3" piping, then about a foot and a half of the stock pipe (O2 sensor is here), then 3" piping again.
