Newbie questions. Need your opinions please
90tsiawdturbo
524
Apr 23, 2010
New London, Wisconsin
Ok I'm somewhat new to dsms and have a few questions that may seem dumb but o well here goes...
First what mods should I do to get a fun street car...I'd like to run an evo3 16g and get around 350hp(just a number so it can be more or less). And not like I want to get the cheapest parts but I'm on a pretty tight budget also. And yes I have read the 1g upgrade path just didn't know if I had to buy everything on it for what I want
Can I run an aftermarket fpr on almost stock car as long as it's the stock fuel pressure ( stock fuel pump and stock blue top injectors) and the box says it's for 95-99 talons will it work on my 1g? (I got a good deal on it and it's new in the box so I couldn't turn it down)
I just bought another 6 bolt that didn't come with a CAS... Can I just take mine off my motor and bolt it right on or is there anything special I need to do
well that's it for now but I'll prob have more as my motor swap continues and thanks for all your help guys
The FPR will work itself, but if it came with fittings (ie. if it is a full kit for 95-99 talon/eclipse) the fittings wont work as the fuel rails are different.
Yes you can take your old CAS off and put it on the 6-bolt you got. GL!
