new talon tsi need help
turbox
Feb 19, 2007
rlsinore, California
ok i just got a 95 talon tsi awd turbo.....its automatic....at 1st the tranny got messed up every forward gear felt like neutral the car would just rev up and not go anywere....so i had the trans rebuilt....now it seems fine but sumtimes when i approach a stop and push the brake pedal in to fast the car stalls...### could b wrong? also do all talons leak oil ....it seems to come from under the headers?my car is stock ecxcept for a t3 turbo i think
Is your BOV recirculated? Venting to the atomsphere will cause the car to stall if your're dropping your RPMs very fast. Also do a boost leak test and fix any possible leaks.
There are a couple places oil could be leaking from. Check your oil pan, your turbo fuel lines, and all the gaskets associated with this area.
