neuspeed with GR-2's
xorti7
May 3, 2007
Federal Way, Washington
I just picked up a set of neuspeed race springs and kyb gr-2's used. Does anyone know anything about neuspeed race springs? Drop? Spring rate? Also, attached are pictures of the springs. In the second picture, the one on the left looks good to me, but two of them look like the spring is not seated correctly, but I'm not sure. Is this ok, or do I need to assemble them correctly before I throw them on? :dsm:
incase more information is needed. That one on the right is up over the perch lip and the other (no picture shown) is back behind the lip about an inch on the perch instead of up over it. Are either of these situations ok?
If the tang on the spring is not lined up with the seat, just turn the mount at the top of the shock and *voila* the bottom lines up now. Just make sure they are lied up when you get them on your car before you drop it off the jack. It's actually no big deal as they will find their seat after a few bumps while driving.
